@yahoo0212
theres hardly any diference in SQ between pre out and tape out, but the points to be remembered
1.tape out is fixed gain - no control from the amp
2.generally whatever source is selected it comes out of tape out
3.in some receivers, digital sources (if TOSLINK,coaxial is used in the amp) don't come out of tape out, listeners tend to miss this point! so only analog sources can be received from the tape out
@madhu_7
you have to connect pre out and amp-in in your receiver, otherwise whats the power amp section will do? what comes out of pre out is amped by the power amp section, once you remove the jumpers and keep open the amp-in ports you get huge rumble!
