rikhav
- Joined
- Mar 27, 2008
- Messages
- 2,673
- Points
- 113
Had an opportunity to listen to bhagwans setup after almost 10 months
The cabling was changed and speaker position was fine tuned from last time I visited
This resulted in a big change in the overall sound of the setup from what I listened to last time
As posted earlier, the speakers just vanish (amazing fof the fact that the room is not huge and speakers are no way small )
The tonality of the instruments feels very real and bass is super controlled and tight
The imaging and soundstage depth and width at par with the tidal bookshelves which itself are very good in that department
The vocals have more presence then before and it's a treat to listen to a good vocalist
Overall the setup is performing very well and has all the traits of good synergy between all the components of the setup
Thanks for the session bhagwan. It was a small one but satisfying one
