Hello friends,
Hope you and your loved ones are safe.
Thanks to the lockdown the idle mind has started to imagine what-ifs . I'm using 2A3 tubes right now and am considering experimenting SS amps with my Maargas. A 300B is still on the cards but may be later.
First Watt amps were the only ones I could find. More than 15 Watts would be wasted watts and heat. The SITs are unobtainable so the F1, F3, F7 look like the best candidates. The J2 is also current production although more power. The J2 is $4K, F7 is $3K and SIT3 is $4K.
If I were to take the DIY route looks like there are 3 choices. J2 Clone, F3 and SissySIT. There seems to be not much activity on the F3 any more. The J2 clone will be expensive because of the Semisouths (still cheaper than the original J2). I don't think there is a DIY F7. BTW, I don't mind paying more for a "better amp".
Any experiences? Suggestions? Other options worth considering?
Thanks for your time and be safe.
