Mauro's "Myreference Rev.C" building queries and guide.
Round holes and threading for 3mm holes with 0.5 pitch are easy enough, for about 7 to 10 rupees per hole. This is from practical experience I had recently.
It is the square or rectangular holes that would need to be pre-cut for things like IEC socket.
A standard enclosure could come with a minimalist rear panel - one pair of holes for RCA in and one for RCA/speaker-terminal out at a slight distance from each other to accommodate further drilling in between, and at a "safe" distance from the IEC socket hole. Another 12mm hole for a fuse holder next to the IEC socket is also always required.
The front panel could contain 3 9.8mm holes - two for volume + selector and one for a SPDT/DPDT switch as a standard. Dimension may differ for the switch. Add an additional 3 to 5mm hole for a 3mm led above or nearby the switch hole (need to check led holder dimensions).
I think the myRef enclosure GB/discussion warrants a separate thread. Although I understand that the casing is also part of the build, I think we should not dilute this thread with casing posts. What do you guys think?
Which of these LED holders are avail in the local market?
We will need the specs in mm for chassis holes as well...
Linuxguru
Will there be any problem if the heatsink of my ref amp touches the casing (Which has safety ground with earth wire of power in connected) ?
There's no problem as long as it's an LM3886TF chip-amp, or an LM3886T with an insulating spacer. Grounding the heatsink is fine as long as there's no circuit node in contact with it.
Can We use "logarithmic" 25K dual volume pot ? Which brand/company one should look for ?
linux
why can the chip not be mounted in this fashion
i dont know much about electronics but this kind of mounting seems to allow a bt of flexibility and tolerence.
seems as if the chip can adjust to the tapped hole in the heat sink
if yes this solves many problems in chasis build
Also what is that spacer kind of packing between the black thing ( im assuing the chip) and the sink?
From the pic, it seems that those are power BJTs in a TO-247 or similar package. There it's possible to bend the leads in several ways (there are only 3 leads, and they're usually made of plated copper, which is easy to bend) and that allows flexibility in mounting.
The LM3886, on the other hand, has preformed leads which may break if bent excessively. It has a small amount of play, but it has to be mounted upright because that's the only way the leads will go into the PCB.
The spacer material between the LM3886TF and the heatsink is optional, but it seems to be some kind of white silicone thermal-interface material in the pic posted by Quad. One could use the gray insulating material found in SMPSes also.
Yes, you can use ganged log pots if you can get them. Alps is probably the best, but may be expensive and/or difficult to find. If you can't find logarithmic, linear will be fine.
Elna India has good stepped relays. for my next project, I would get the Vishay/Dale resistors in bulk and assemble them on my own own.
Here some guy has totally done away with heat sink and fixed the chip to some kind of plate. Is this possible ? layout of connectors is also good only transformer power in is running over the pcb I think.
This is from the older DIYaudio group buy (~2008), judging by the components and green solder-mask. The side-plates *are* the heatsink, just like the F5 cabinet posted by Quad, except that they don't have horizontal fins. This is entirely practical, because the LM3886 doesn't actually dissipate much heat in operation at normal volumes.
What are stepped relays? What would you assemble with the Vishay-Dale resistors?
I meant I would build my own stepped attenuator rather than spend $150+ on an audiophile one going forward .... a rotary switch sorry
Something similar to the old fan controllers we used to have with 1 for slowest speed and 5 for fastest speed albeit a more refined one.:ohyeah:
