Hello Team ,
with so many options i hate to step into any showroom to even for a demo.
The available choices really strains my bird brain.I need your support in helping me narrow down to the model numbers and i will just go and buy the damn thing - lol My specifications are below.
1)Main SPECIFICATION - I like big size so i need a tv that is a minimum of 40/42 Inch.I don't want bigger than 42 as the budget will continue to rise.And i wont buy a 32 Inch.
2) My Budget - as per the market.I cant limit myself of 30 K when i need a 42 Inch TV.As per the market price for any TV of 42 Inch is fine.
3) I don't watch much TV at all.
so It doesn't matter to me if my TV can connect to internet or not.whether it is 1D/2D/3D//4D/or 5D.because one has to sit with the silly glasses to get the feel of the effect.i neither have the patience nor the time.
4)viewing distance is 4 or 5 vitrified tiles - i guess it should be 8 ft only
5)there are two windows on either side of the wall and the main door opposite to the TV Stand.
6) I cant really make any difference between FHD or HD.
7) We use normal cable TV connection at home.if required i can change to dish TV or tata sky or simply a set top box at the minimum if required.
8) I don't understand the smart functions
9) It doesn't matter if it wi-fi ready.
10) i as a common man cannot differentiate PQ.what panel it uses etc etc.to me all look the same.
11) i just need a product that doesn't fail or has any defects.I really cannot afford the run around(calling the CC or dealer and so on and so forth)
12) Any make cheap and best value for money would suit me.Looking forward to your recommendations.
13)LCD/LED/PLASMA any thing will do for me as long as its VFM.
Not to forget- best recommendations provided will be rewarded.let me know if you need any further info.
I am from ECITY Bangalore - also please let me me know which dealer i should buy it from or which dealer i should avoid.
My apologies if i sound blunt but I know i m really dumb - unfortunately i need to make a decision urgently to pick one from ocean of TVs
Looking forward to your continued support.you guys really R.O.C.K !!
