Hey Vint, you could get a neat high end active speaker system. The Genelec 5040 + 8020 system is available from Pandam in Mahim Bombay. PANDAM Professional Audio but its not cheap
strech your budget a little bit and go for the creative gigaworks T3 they are very good speakers and worth the money u pay for.
If 2.1 is your option then for that price dont go for any systems in the range of 3-6k as they are all the same, they have the same 4-5.5inch subwoofers which are no good. So you will shell out the money for no reason.
Instead either get a 2.1 sytem from creative or logitech .. for around 2k. or then go for the 2.1 z2300 from logitech for around 8k ... which i bought recently.
If u got for the z2300 i can asure u, you wont be begging for more , that system is more than sufficient for a computer.!
Did you even attempt to read the original post before replying? His budget is < Rs. 5K. Genelac is magnitudes more than that. Did you think by hearing the name, he would automatically become a convert and raise his budget 10 fold? hyeah:hyeah:
The models listed, does not have "that" huge a sub, can be easily placed below your computer table. And since you have a budget of 3,4K you might as well got for 2.1 as against to 2.0. The difference in audio is also worth the option.......
