Hi all,
Recommendations sought:
I am currently the owner of the Harbeths SHL5, which I loved and enjoyed for a while now. I have paired them with Trigon Exxceed amplifier (Dual mono, 120W/170W per channel at 8/4 ohms). My sources are both vinyl and FLACs and my music taste ranges from western classical to old Bollywood, classic rock to blues and motown.. everything, but nothing too heavy.
I recently happened to drop into a hi-fi showroom in Goa, when I was travelling, and listened to Audio Note folded horn speakers (not sure of the model, but was one of the base models, I think. They were being driven by phono+integrated tube amps from the same brand, also base models) and was blown away by the life and dynamic-ism of the music. The cellos sounded so life-like and present, the sound stage and imaging was also brilliant. The most immediate quality was the presence and liveliness of the instruments. Since then, all I notice from my setup is the laid-back warmth and lack of punch, which may be more psychological, but is still a constant niggle.
So, if I start thinking of changing my speakers, and eventually maybe even move to tube integrated or separates (but not immediately. I will stick to the Trigons for now), can you please suggest:
1. Which direction I should look in - horns or cone/dome speakers, to match my current amp?
2. Bearing in mind what I am looking for (above paragraph), can you please suggest speaker brands better than or as good as the Harbeths, but with more liveliness, dynamics and punch, especially at lower volumes?
3. My budget will be around 3L INR (with some wiggle room), any specific models I should consider? Used or new?
Thanks guys
Thanks guys
