Bought a Sony KDL-46EX520 after months of battle with Samsung to fix my 3 yr old 5 series 40" Full HD LCD. Last offer given was 20k for panel replacement with 30 days un-written warranty.! Didn't find spending that amount for month worth it.
Anyway coming to the topic.
Bought from local Kohinoor store for 80k after exchange (knew the guy so got more realization for my conked TV).
Design: liked the thin bezel design which makes the screen look even bigger than it is, but the thicker bezel at the bottom is a turn-off for me. anyway still acceptable. The bottom bezel is ash-silver with a chrome sony logo in centre.
Pretty thin over all and the wall mounting bracket is also quite thin jutting out just an inch or so from the wall.
Connections: refer KDL-46EX520 : EX520 Series : BRAVIA HD TV (LED & LCD) : Sony India
Picture: boasts the Bravia X-reality with edge LED but the refresh rate is 120 Hz i think. Normal SD channels from Airtel HD box look quite bad from close range, but from 8 feet or so its much better than my earlier TV. HD channels look quite good, but while watching Transporter on movies now hd you can make out the haziness in fast movements (guess thats what is called jaggies).
DVDs look super good, with the blacks and dark scenes handled quite well. Not on par with some panasonic plasmas i had seen before buying this one.
Initially the picture looked quite dark, then i realized there is a light sensor that dims the picture in dark environments. put that to "off" and it was much better.
have some blu-rays but no player, so cudnt check the 1080p picture quality yet.
Has ethernet port to log on to internet, but haven't tried that either so can't comment. The GUI is quite nice and easy to operate with loads of tweaking options. The "default" settings made the picture look quite dull. Other wise the "standard" setting in "picture" looks quite vibrant. I found the colors to be more closer to reality as compared to some of the samsung, lg and toshiba sets i had seen while buying. especially skin colors.
Sound: very bad. very bright and lack bass completely. but for normal everyday TV its good enough. for music and movies to be enjoyed you will need external speakers to be connected.
nothing that comes to my mind beyond this right now, will post some pictures and HD video feedback shortly.
cheers
cheers
