Suggestion Required for Vocal booth and Control Room acoustics
arjunkr
bangalore
Hi all,
I am new here in the forum and also for Acoustic knowledge.
My Requirement as follows :-
Basically I am into professional Post Production for Movies.I have bought a studio in Malleshwaram which had basic vocal booth and Control Room.The room has already done acoustic before [1 inch glass wool with 2 mm ply sheet on top on all walls],but the problem is the the vocal are heard outside from sound booth room and viceversa , due to this there is problem with recording of vocals,
The control room sound from monitor speakers are heard outside too, I need to sound proof the control room and vocal booth.
Kindly suggest me the things to prevent the problems :)
I will be posting the pics in a while
You need to decouple the walls with another false wall and tightly seal all the leaks through doors.
The current acoustics may be with 2mm perforated ply with 1inch glass wool. If so, it will not do anything for sound proofing.
