Sridhar,
My impression was that the Maggies are 'relatively' easy to drive. Folks seem to be happy driving Magneplanar 1.7 with 100WPC/ 8 ohms. Something like a Bryston 3B SST is considered to be perfect for driving the 1.7's. Your post seems to suggest that the maggies are a very tough load to drive. I am asking, because the 1.7 is one of the speakers I am considering for a future pairing with my 4B SST. I would appreciate if you can take some time out and post at length.
Also some amp suggestions for anm.
I am not sure how you can call them easy to drive - however, I am talking about Maggies in general - I haven't looked at the plots for the 1.7 - a quick search got me the following info from UltimateAvmag about the 3.6s
The MG 3.6's sensitivity measured approximately 80dB at 2.83V/m. Its minimum impedance in the lower midrange and below was 4.1ohms at 150Hz, dropping to 3.4ohms at 10kHz; I would rate the nominal impedance at 4ohms. With respect to impedance (both magnitude and phase), the MG 3.6 should be relatively easy to drive for any amp comfortable with a 4ohms load. This benign nature is fortunate, given the 3.6's very low sensitivity. I strongly recommend a high-powered amplifier to drive the Maggies. Its 80dB/2.83V/m sensitivity will require four times the power of a speaker measuring 86dB/2.83V/m (more typical of consumer loudspeakers) to produce the same sound level.
when manufacturers were 'honest' for lack of a better word, the nominal impedance was the value which was typically 25% above the lowest impedance point. For the maggies, the impedance can swing from 3 ohms (assuming 4 ohms is really nominal) to 12+ ohms. Thats equivalent to taking a car on a downwards slope and immediately going to an upslope. These loads are not easy for any amp to handle, furthermore the impedance is a complex one.
Himadri posted a link about how amps don't make much difference in sound with these speakers - I am a bit skeptical about that. The sound of these speakers is quite different from traditional sound, in that respect everyone who hears this (when not used to ES panels) ends up hearing something that is extremely large, very airy, open, etc this sound signature dominates over everything else with this speaker. As a result if one tries various amps in a store, the differences in tone/timbre can easily be overshadowed by this larger than life sound....in any case this is what i think.
Ajay, the other thing to note is that these speakers are completely dipole - these are hell of a lot harder to setup (ofcourse this has nothing to do with impedances or drive). I mention it only because you seem to be considering these as well. From what I have heard, the King Sound speakers provide much better value.
The other thing to do is to go with autoformers to effectively raise the impedance seen by the amps. The other thing to note is that Magnepan specs the sensitivity at 500 Hz, not at 1Khz like most of the other companies do
Also in our staple, the Odyssey Khartago may do quite well in terms of driving them since they are stable at 2 ohms. This is still in the 60K range.
cheers
