WDTV1 - Audio Issue
zorro
Hello all
In order to play 5.1 DTS WAV audio files in WDTV, i wrapped the files in a Matroska wrapper (.MKA) using MKVMerge.
The file plays fine in WDTV and my AV receiver recognizes the format and outputs as 5.1 DTS. So far no issue, however after every 4 minutes it gets stuck and the audio is all chatter. I then have to press the forward button for a second and then it resumes playing fine. This pattern continues every 4 minutes.
Any ideas or workaround for this problem.
Thanks for the help
Zorro
Try any old version MKV merge to do the job .....sometimes the new version 4 2 2 is giving problem.......try version 3 0 0
Thanks. I downloaded the version 3.0.0. Will try with this version and get back to you with the result.
Currently i am using version 2.9.8
zorro
Hello
I used version 3.0.0 of MKV Merge to wrap the audio files (.MKA), but still the issue persists.
Any ideas
zorro
