Western Digital WD TV HD Media Player - a HTPC replacement??
Vinay got it from:
Maccan Infosys
347/45, Rajesh Building,
Opp Lamington Road Police Station,
Dr D B Marg, Grant Road,
Mumbai - 400007
Tel: 02223891916; 02266586595
Contact persons: Mr Amit Mehta, Mr Bharat Mehta
Hey thnx a lot friend!! :cheers:
I will call them tomorrow and lets see what price they quote!! fingers crossed!!
Guys, I am looking to buy a WDTV in Hyderabad this weekend. Any ideas where I can get the best deal?
Last weekend i bought from CTC (near Paradise) for 7200/-. I checked some other stores in HYD but i found it was the best deal. May be u can check some others too.
Mohan.
Hi friends,
I have a Phillips HTS3544, it has only a co-axial input (not optical in).
If i want to connect my WD TV media player and get DTS and DD 5.1 sound, will an optical to co-axial converter work for it?
Will my Phillips HTS3544 decode DTS and DD?
If so, where can i get optical to co-axial converter in Hyderabad? Any one have this kind of setup? Will it work fine or sound quality loss?
Thanks in advance.
Mohan.
Hi friends,
Thanks in advance.
Mohan.
The concept of digital ins without decoding DD and DTS sounds a bit silly to me . I think It should be able to decode Dolby Digital as well as DTS. However check it out to be 100% safe just in case.....
hello friends!!
I just got a doubt! If I connect my Media player (which I havent got till now!! :P) to NON-HD tv's such as a simple CRT tv via RCA cables and play 1080p movies on it.....I know its no use as far as quality is concerned but I hope the tv will still play the file! I hope it wont show some error like this file cant be played (just bcoz its 1080p )!!
So will the TV play the files??
hello friends!!
Yes, it will play. From manual:
If you are using a CRT TV, navigate to the Home | Settings | System screen and:
- Make sure that the Composite option is selected as the video output.
- Make sure the TV system setting matches the system used in your region.
Hi friends,
Thanks in advance.
Mohan.
Yes. madbullram currently uses one and the convertor works just fine. MX imports these convertors from Taiwan. The price quoted on the phone was around 1200 excluding taxes with 1 year warranty. The other option is to source it from US. Amazon has this convertor listed and if you can get it through someone coming from the US, it'd be a cheaper option.
There is a person on the Techenclave forum who can source anything you want from the US (katmandude) and charge a service cost for it. The amazon product would cost you around 1150 through that source + shipping at actuals.
It costs about Rs. 800-900 in Lamington Road, Mumbai. Be sure that you buy the right one. i.e. Optical In and Co-axial Out.
(Vice-versa is also available).
Thnx for the reply!! :clapping:
BTW I called on the no. that you gave .......I asked about the price of HD media player and the person said "how many gb" !! Then I clarified I want the media player and not the Hard drive and he looked confused!! Then I again said the media player which plays movies....Then he said- Ok that we havent got it till now so cant tell the price!! Now thats strange!! :-?
Vinay had bought HDD and WDTV from 2 different shops, so some confusion maybe. Try the other one now:
Ossian Informatique
Shop No.13, 1st Flr., Yamung Bldg., Tara Temple, Lane, Lamington Road, Mumbai-400 007
Tel: 02223889905
Mob: +91 9321412326
Ossian Informatique
Tel: 02223889905
Mob: +91 9321412326
Thnx for the no.!!
Cell phone was switched off and no1 picked the phone on landline!! :( I will try later and lets see what happens! :)
Thnx for the no.!!
Sorry, these were the numbers given to me, I had never called them. Now I tried. i think the mobile no. is wrong!
You can try my source: Venktron. They are distributors for WD.
Tel: 02223874427
Ask for Mr. Mahesh
Tel: 02223874427
Ask for Mr. Mahesh
Called Venktron! Their price is Rs 7000 /- including B & W
Hi all,
I tired many stores in Hyd to get optical to co-axial converter but didn't find them.
Any one know abt any store in hyd where i can get it?(I tried the 3 stores provided in the link for MX given by Kneo)
Hi Reju,
is there any way it can get it from Mumbai?
Mohan.
Hi all,
Hi Reju,
Mohan.
Did you try Reliance Digital, Croma and X-Cite? These 3 are the best sources for Hi-Fi and HT cables ranging from the superexpensive to the budget ones.
Dunno about X-cite but other 2 keeps "popular" and General connectors - such speciality devices I never saw.
Hi all,
Hi Reju,
Mohan.
You can order it through Amazon via the dealers on techenclave.com (katmandude is the name of the dealer). The charges would be similar to getting it shipped from Mumbai.
