Yamaha Avantage 1080
anandshah
Pune
how is this AVR also i am not able to find whats the Pre Amp volt out signal strength incase i want to use External Amplifier for LR
There are 2 subs out if it LR or 1 sub and 2nd sub
regards
anand shah
regards
anand shah
Yamaha preout are not good, i read few review and all suggest marantz have cleanest avr preout, if its for movies try denon new denon avr are superb for ht. Also denon pre out are pretty clean.
If you can audition, then that's the best way to decide. It's worth it even if you have to travel to the closest city where you can audition.
MaSh
