I have bought a brand new Yamaha Aventage Receiver from USA and I stay in Mumbai. The model number is RX-A840.
When i bought it in US, i had tried starting the receiver and it used to work. The power specifications behind the receiver were mentioned as 400W.
Currently I am in Mumbai, India and I bought a 110 step down converter from a local electricals store and got it tested that it gives 110 as output. The step down converter is capable of handling 500W. The step down converter was tested to give output of 110V at the shop while buying.
Then I connected AV receiver to step down converter and was trying to start it, but it was not turning up. The pure direct button when pressed was showing blue light when button was pressed, but later on even that stopped working.
When I took it to the shop from where I bought the Step Down Converter (named: Maru, is a maharashtra based co.), he mentioned that there noise of relay coming from the AVR.
I replaced 500W step down with a 750W step down, even that did not work. Finally i have ordered 1 KV step down, which is my last resort.
Have anyone faced similar problem before, if yes please share how was it resolved.
I also contacted few service centers in mumbai, one of them mentioned that he can get the voltage converted to 220 for Rs. 3700/-. I am also concerned about the warranty, as I don't want to do any changes until 3 years of warranty is expired.
Appreciate if anyone can provide the solution to the problem.
Manish Sachdev
