goyal.sanchit
Hello Everyone
I have an Optoma HD 600x projector. It is about 1 year old but have been used very less. About 100 hours or so.
1-2 Months back I was watching a movie on it. Suddenly the projector turned off and a combination of lights was blinking. I suspected Lamp overheating though the AC was on and projector had been running for just 1-2 hours.
This is what the user manual says about troubleshooting-
There are 3 lights on the projector. The power light, light with lamp icon and the light with thermometer icon.
The lamp led was steady red and the power led was flashing red which according to manual indicates lamp failure!
I was surprised and worried since the projector was hardly used. Anyways I switched off the projector, Prayed to God and switched it on after some time and it worked well.
After that I used it 4-5 times and it worked good.
Today again the same thing happened. Projector turned off with the same combination of lights. Switching it on after some time worked again.
So what is this error and why does this happen? Seems to be lamp overheating but the overheating indicator is never turned on and the combination of lights suggest lamp failure!
Also in general how can I protect the projector from dust?
Its in the Bedroom ceiling mounted so putting a cloth over it would look bad as well as fly because of the Fan. So is there anyway to protect it?
And I do not cover the lens with the lid as it can move the focus ring and setting the focus eveytime would be a nuisance. I hope it not much of an issue or is it something that must be done?
