Help me to decide my 3D monitor for my PC. what features and considerations to look for?
PHILIPS 238G4DHSD - response time is 14ms and smart response time for 2D is 7ms - what does this mean?
AOC D2367ph
VIEWSONIC V3D231
LG D2342P - not available anywhere in trichy or online. Do you know any online?
Any other monitor available around 15k range?
How to convert my monitor to TV? How can I connect my RF (cable tv) input to monitor? Do I need a TV tuner Card? I am looking for a cheap -mid range TV tuner with TV recording feature. will the i-ball claro enough? So I'll be using TV tuner's remote for changing channels right? Do I compulsorily need a SSD for recording? I have a WD Blue. My recording needs are minimal and it should be viewable.
Will 23 inch monitor will be too small for a TV? Should I go for a 27inch?If so 27 inch AOC or 27inch Philips. ?
In case if I choose AOC 23A6730/61 TV to connect my PC for monitor use, Do I need a TV tuner to record TV programs? If,no how to?If yes how to?
Can anyone take some time to explain this please? I am new to this.
AOC D2367ph
VIEWSONIC V3D231
