The Concept With the new RAINBOW CELL
ARTOS AUDIO created a great speaker system using an intelligent 6dB crossover design that offer high efficiency combined with perfect phase linearity and very linear impedance behavior.
Listening rooms of 20m and a high-quality amplifier with just 20 Watt output power per channel will allow the Rainbow its full potential.
The Cabinet The cabinets of the RAINBOW CELL are handcrafted by skilled carpenters using our multilayer construction.
The Airflow construction, numerous internal braces and the lute-shaped design minimize the vibrations of the enclosure to an absolute minimum.
The CELL-Concept Tweeter and the CELL-Concept Midrange are housed in their own chambers to further improve the soundstage and imaging.
The precious and elegant look of the high-gloss real wood veneers confirms the status as an exclusive ARTOS AUDIO loudspeaker.
Inside The RAINBOW CELL is the first ARTOS AUDIO speaker system using Accuton CELL-CONCEPT drivers throughout the entire frequency range.
The advantages of the CELL-CONCEPT are: - Same acoustic center for tweeters, midranges and woofers for time coherency in a flat front - Perfect signal settle and piston behavior of the dome even close to the dome resonance - Very low distortion - in the magnitude of electronic devices - even at high power levels Crystal clear highs are obtained by a 30mm ceramic tweeter; optional a 30mm Black-Diamond Tweeter is available.
The 5 CELL-CONCEPT midrange driver is used over a very large frequency range from 300Hz up to 2.800Hz. Three 8 aluminum/ceramic woofers deliver a clean, tight and very deep bass.
Extended-Version As an option, the RAINBOW CELL EXTENDED demonstrates our passion for music and our permanent ambition to turn a perfect speaker system to another level. The external crossover allows us to forget the limited space available inside the RAINBOW CELL.
Not only better parts made by Mundorf and Duelund find their place in these crossovers, there are NO vibrations from the drivers taking impact on the individual parts. In addition, biwiring, tri-wiring, bi-amping and tri-amping are possible.
RAINBOW CELL System: 3-Way-Airflow-Design Cabinet: resonance optimized multi-layer construction Driver Arrangement: 1 x 1,20 ceramic Tweeter 1 x 7.00 ceramic Midrange 2 x 7.00 ceramic Woofer graphite-coated or white (custom made by Accuton)
Impedance: 5 Ohm Efficiency: 91 dB rec. power: 15 - 200 Watt @ 4 Ohm Frequency range: 30Hz - 35kHz /-3dB Terminal: WBT single-wiring Terminal Crossover: hand built by ARTOS AUDIO using exclusive Mundorf parts internal cabling: PCOCC construction handmade by ARTOS AUDIO Spike-System: 8mm stainless steel Spikes optional ARTOS AUDIO Resonance Technology Spike System
Dimensions: 112 x 26 x 42cm (H x W x D) Weight: 43 kg / each - 58 kg / incl. packaging
System: 3,0-Way-Airflow-Design Cabinet: resonance optimized multi-layer construction Driver Arrangement: 1 x 1,00 ceramic CELL-Concept Tweeter 1 x 5.00 ceramic CELL-Concept Midrange 3 x 8.00 ceramic CELL-Concept Woofer graphite-coated or white (custom made by Accuton) Impedance: 4 Ohm Efficiency: 92 dB rec. power: 15 - 300 Watt @ 4 Ohm
Frequency range: 24Hz - 35kHz /-3dB 24Hz - 90kHz/-3dB for Black Diamond Version Terminal: WBT single-wiring Terminal Tri-Wire Terminal for Extended Version Crossover: hand built by ARTOS AUDIO using exclusive Mundorf parts additional Duelund parts for Extended Version internal cabling: PCOCC construction handmade by ARTOS AUDIO Silver-Gold-OCC construction for Black Diamond Version Spike-System: 8mm stainless steel Spikes optional ARTOS AUDIO Resonance Technology Spike System Dimensions: 123 x 27 x 52cm (H x W x D) Weight: 55 kg / each - 70 kg / incl. packaging
