bhagwan
Re: Rockport technologies
Since you like the Harbeth Sound, take a demo of the Top Line Model & use it.
India has a D & D in Bangalore & I am sure he will 'accommodate' you on your needs.
It is a good speaker if you like 'british' sound.
BTW - are you open to used hi fi in India ? Or do you only want to buy brand new Audio Gear !!
BTW - I have used Dynaudio C5 in the past & they were super speakers - but the C1 looks better than it sounds.
The Focal is an excellently built product. If you like detail & resolution @ the cost of Musicality it is an good choice.
The only issue is will it mate well with a Lamm & SL [Amplification] ??
Sir,If I like a speaker a lot, then I will take the pains to import it as I have done for my Harbeth.
Sid
