saheb11123
I'd reconsider the percentageThink of it this way - done right, it's probably 99% of the sound at 99% [not really, but close] cost savings.
Sent from my SM-G610F using Tapatalk
Great work Sanjeev!
I am also using a Raspberry Pi 3 with Allo Boss DAC for casual listening in the dining area with Adam A5X active speakers. I was impressed with what this cheap DAC could do. It produces very smooth and warm sound. I also compared it with DragonFly and Chord Mojo.
I chose to use an iPad (or any mobile phone on the table) to control Volumio, instead of a separate touch screen display near the system. Anyway that is just a personal usage preference, with no impact on the sound. It is exciting to see how technology is evolving now. The end users like you and me have so much control over how we create and upgrade stuff based on our individual choices. I am glad that local companies like Allo are producing great world class products.
Sharad Medhavi
Which arcam dac have you got and what is the dac chip?@JLS,
I have noticed that this player plays Flac files really well. The o/p is very very sweet and musical, with awesome detail. In Wav files, the o/p is clinically good.
The Arcam does better on WAV files.
Perhaps there is a difference in the way decoders have been written on the two systems !!
Sent from my ASUS_Z00AD using Tapatalk
Thanks let me try ! What would be the power? Means watts, ohms etc
can I increase the watts and ohms?Power is 50W per channel into 4 ohms.
I tried using a buck circuit to power the RPi, by taking the output from the 24V 5A SMPS which is powering the class-d 3116, and lowering it to 5V by the buck circuit.
The result was a hiss and a disappointing fall in SQ from the RPi+Boss. Restored the RPi adapter supply, and got back the SQ.
Obviously, the DAC is sensitive to the hi freq noise that the buck generates.
Wondering whether to buy a Capacitance multiplier, or a linear supply for the 3116D2 .....
Dear Members,
i am also planning to build rasberry pi dac for my audio system. all i need is rasberry pi connected to dac and usb hdd for songs. control is through the lcd display . may be using mobile also . but i don't want it to be connected to internet. is there a way to do it? a stand alone player .
R.Suresh.
To add to Kane's post:get Volumio create a bootable sd card with it and run it on the raspberry pi. Volumio also run in hotspot mode and will create a wifi hotspot, which you can connect your mobile to, this way the raspberry will not be connected to the internet but will still allow it to be controlled by a mobile.
Why in this world, one would use a tpa class d amp for hi-fi music listening, i believe its a serious project here but ruined by a crappy chip, ...
I wouldn't, by any stretch of imagination, call TPA3116/3118 crappy chips when implemented correctly and used in the linear operating range.
Hmm... I would first do an actual shootout A-B blindfold comparison before I would comment on sound quality.yes agree, when implemented correctly and with proper pcb layout it may sound fine.
but, if we come out of imagination, it is still crappy for "for hi-fi music listening"
i would consider TDA8922 over this if i have to go for a medium power class D chip
