Now that we have quite a number of V20 owners here, it's time to start discussing settings, problems and impressions.
I got my V20 two days back for 60.5K. I'm still playing with the settings. Here are my dark room settings, obtained after using Pixar HT setup and cross-checking with slides from this site : LCD monitor test images I could not do colour calibration as I don't have proper references, so I'm leaving the colour settings at their defaults.
Mode:True Cinema/Professional 1
Contrast: 10
Brightness: 0
Colour: 45/50
Sharpness:0/10
All other settings to 'Off'. Especially, Setup->Other->16:9 overscan should be set to 'Off' as turning it on crops the picture slightly.
For daytime viewing I'm using,
Contrast: 6
Brightness: 4
Colour: 45/50
Sharpness:0/10
I have to admit my daylight settings look very dull, compared to dynamic mode but my eyes get used to these settings in a few minutes.
BTW, if using a PS3, make sure you set RGB range to 'limited'. Otherwise you'll miss black details completely.
Till now I've noticed all sorts of problems like colour banding, dancing pixels, fluctuating black levels and incorrect grayscale but I guess I should 'run-in' the TV before judging these problems. Color banding and dancing pixels were rectifiable to a certain extent by changing settings to what I've given.
PLUS POINTS:
+ Very detailed picture with bluray material. Unfortunately, the level of detail this TV is capable of producing also exposes the defects in lower bitrate files.
+ Good black levels but the TV doesn't disappear into the dark like my Sony CRT does when displaying a black image. I read that even VT20 and Kuro don't disappear into the darkness and they too light up slightly even when displaying a completely black image.
+ Very low screen reflectivity. Almost looks like an LCD monitor.
+ No image retention under non-dynamic settings. But dynamic mode, it creates IR within minutes. An interesting fact is that there are no screen burn protection options in this TV.
Would like to know if anyone found these options hidden under some menu.
Contrast: 10
Brightness: 0
Colour: 45/50
Sharpness:0/10
Contrast: 6
Brightness: 4
Colour: 45/50
Sharpness:0/10
PLUS POINTS:
