sony kdl 46xbr6 frm usa
gr_babu
hi this is babu from chennai.
This query is for my FRIEND deepaK.
He is planning to get sony kdl 46xbr6 from usa,
will it be compatible in india,
like will it work india (we r using 220 volt and in usa its 110 volt)
secondly ntsc and pal issues for watching reliance bigtv dth in india.
like to get information on these issues.
help plzz
thx in advance , help pllz
Babu:
The complete specs are available at KDL-46XBR6 | 46" BRAVIA® XBR® LCD Flat Panel HDTV | Sony | SonyStyle USA
As per the Sony/US specs, the TV seems to accept only 120 volts. So if you have to use it in India, you have to use a step down transformer.
There also seems to be an issue the TV System. the Sony 46XBR6 seems to accept only NTSC/ATSC. I am not too sure about Reliance. Most set top boxes that come with DTH systems can handle both NTSC and PAL. I am sure Reliance can also do that. But the Sony TV will not be able to receive any transmission that is in PAL.
Can your friend not buy it India or someplace like Dubai, Singapore or Malaysia?
hi
thx for the reply, this clears our doubt,
but the similar model is not available in asia .
thats the problem
thx for ur reply
ha thx for the information,
what would be the price of the above mentioned 46x4500 series.
i mean the approx price
thx
it would be the same or even less then the current thats just my opinion based on price reduction on S series,V series lcds.
