Venkus Narelius, here are a few bits of advice from me.
Any wall unit like the one you are looking at need to have a number of safety features:
1. The wooden cabinet has to be made well, preferably using hard wood planks. Most Indian carpenter make four ply boards, and just nail them together. This will give way in time, particularly if you put weight on them. You have to use Mitre or Dovetail joints with a ample amount of glue to keep the boards together. In addition I would recommend, at least two rigid brass L joints to be screwed (not nailed) inside for each connection.
2. How do you mount these on the wall? Usually carpenters would mount them like you mount frames. Small screws on the wall, two holes on the extreme ends of the cabinet, and hang the whole thing on the screws. This is completely useless. What you have to do is to drill four to six large holes on the wall. These holes have to be filled with plastic or metal wall plugs. A thick brass L angle joint which is about 3/4th the width of the bracket has to be stuck to the wall using screws on the wall plus. The cabinet has to be mounted on the L joint and again screwed with wood screws.
Remember the plastic or metal wall plugs have to be the expanding type. That is, when you insert a screw and tighten, they expand inside the hole and grab the sides.
3. Even if you do all this, I would not advise keeping either a TV or an AVR on the cabinet.
I have installed such an unit at home to keep my inverter and two large batteries. Instead of the brass L angle, I have used a full length teak plank of 3 inches by 3 inches, and machine cut that into a L joint. Then using metals wall plugs on the wall, I used solid nuts to bolt the L join into the plugs. I then placed a large teak board that bears the weight on these L joints. Of course, the cover for this whole thing was made of ply, but the load bearing parts are all solid wood.
Even for a 32 inch TV that I mounted on the wall recently, the manufacturer insisted on six screws to give the wall mount strength.
In all these activities, unfortunately, you have to take charge and watch over the work. Most carpenters do not have the knowledge and would not even know what a Mitre or a Dovetail joint is.
