Amp enclosures/chasis cabinets
group buy pre order has commenced
3101. Sachu 888 - pass B1 buffer cab
3102. Omishra - 1 bare bones + 2 specialized heatsink cab (similar to this Sound Foundations - Prime-S/R Speaker Stand but no H/W)
if interested please add your names in the following posts with serial number
Hi Magma, is this in continuation to your this post on the Pass B1 thread?
I had expressed my interest to join the group buy here
Is my expressing interest in the B1 thread good enough or do I need to opt in again here? If so, do add me for the cabinet, same as that of Sachin. My serial No. would be 3105??
good momentum going
10cabs are good enough for my effort
will keep the pre orders open a couple days
then we close on the day i order the raw matl
probably friday saturday
Magma
Is there a cabinet that can be used for both Pass B1 + Linuxguru's Gainclone to make an integrated amp?
--G0bble
Magma
--G0bble
You just invaded my thoughts!
i had been thinking along these lines for two days now
but i purposely didnt stae this becase i have absolutely no idea how to adjust everything since i dont have the gainclone etc
If you can make one to fit all these that would be great, even i would like to have one.
Even I'm using Linuxguru's clone ....But fitting everything into one enclosure would mean a different trafo ...and the space requirement would be more . But a nice thought ..
heres a heatsink that arrived today for an F5 Turbo amp cab build
its a monstrous 6feet long extrusion
absolute killer
Here are some prototype pics
cab going to sachu
Note: to all prospective buyers
Please do understand that is nothing but a decent DIY build.Please do not go around expecting a high end pristine finished OEM cab
i will wait for a day if any one wants to pull out or add
The group buy is then closed
Hi Magma,
It looks good.One question,did you forget to drill hole in partition?
Sachin
CRAP!
yes i did!
where do you need the hole and how big
Actaully you may be able to do without the hole becuase the partition is actaully 5mm shorter in height than the sides , so you can actually route the wire over it
i did this puposely since the bare bones guys can make use of it too
but let me know what you think
CRAP!
yes i did!
Thanks Magma,
Please refer this pic,hole size is 10mm.I will also need B1 holes close to input/output as I am not going to use input selector.
[URL=http://imageshack.us/photo/my-images/204/p1000647bo.jpg/] Uploaded with ImageShack.us[/URL]
Sachin
