After Completion of Book-shelf's & Multimedia Speakers, I have started working on my new Project. This new Project will be a Sleek Floor Standers.
I wanted the Enclosure to be Sleek & Height no more than 1 mtr, there was no constrain related to Depth of Enclosure. So I designed the enclosure accordingly. The Dimensions of Enclosure are [900 mm (H) x 180 mm (W) x 350 mm (Deep)]. The calculated Fb is 47.37 Hz & F3 is 40.82 hz, The Port Size will be 4 Inner Dia.
The Woofer which I have used are the same as used in book-shelf's (my earlier project) & Highs are Ribbon Tweeters.
The Specifications of Woofer are as under
Make: Iwai
Output Power: 50 Watts
Impedance: 8 Ohms (Total Impedance 4 Ohms 2 Nos Wired in Parallel)
F(s): 63 hz
Quantity Per Enclosure: 2 Nos.
The Specifications of Tweeter are as under
Make: Audiopur Ribbon Tweeter RBNT1
Output Power: 15 Watts
Impedance: 4 Ohms
F(s): 1.5 khz to 33 khz
Quantity per Enclosure: 1 No.
I also wanted the Enclosure to be light weight hence I selected 12 mm MDF with a Strong Bracing Inside.
A Little Teaser :
Sadik Bhatkar
Make: Iwai
F(s): 63 hz
Impedance: 4 Ohms
A Little Teaser :
Sadik Bhatkar
