Another Project on the Way Slim Floor Standers (M T M)
Thanks, how did you manage those corners without folds on the cloth?
That a little difficult task... the main reason for redoing this job again was to get rid from the folds which mostly appear on the corners.
Update :
Finished the Paint Job of Speaker Stand. I Have Painted it White with Grain type of Texture.
MIqpVeht7EjD4odDfPgQs_TRsISVNkr2Fb9ZwfvyKAStHTzHol9zLK80N9pv6Ok3GGSQKQePJDPSavcrUFeAJ72LtW9gaxH-qxqW7PrlvARs3ZViuqjXPN9BMPQFZq8EOQbWwyc9q9ksIb8qJVK43VrE1rsVI4D7glOjpQJBMjiakh-UIhFAqsNXzP0Q6WhIFxXPOZ0f4BqC1EnqXGWeFzeRF_7v2e3LgyAqUaUPQin20VKwAtUrAiU8IA-InV8GAS66-iOOhsVZ-8faqCWjKu3acidjlmGRp0b2jjf9Qgj4HHxyqX34BfCE6fW4v8cbgZJHW6sNh5KHs_cQc5nx-Npg_vCbQOdQBHb_fpAPN9jkYGTuldS18AQwpUdbMekn7L7cjKgjrilXzOcn0HzQEp8R7HZFZYn_48P4AnWgIrsd6HKxPN263s0I5GIHYtPV6UV-yTpWmv1-GM8NX_IrY9LI44fIFepSowudMlQYyh3uqYbizOHs5dnZFZ0iysUHBC67NLFvcb9rnJ0LQIZHhGHcfc4ZHMlW5q3ZFvsQ0mmEnOhOBOdRvNB7X3XqJ2DY0suUTVEeh5XMuymlZ3I181rTK9qV9IAfuIvG55duow=w693-h924-no
nog4dWluqoMUjM-uvFIuYNSCsQKIr5Uo1HeskOTHPtybx9jyuJBsj4SEdD2x_U1WxzRYhOSfPR2Rbsd-OfDyc9BEchLMaj7-Jq5FEv0BoQrrX_bwbBBoJM3rntkH7iaApAPELO7sESWF6oPEiGb4-9z8hfCRtJ4s5gt7FqATIGs3LZXYhzJTOI_FiatxZGMQsNpnKmiOpw3mysiTq6CNZBcF8qJOal1pKvpBS9-jaafT_XeAWKZ11zqotKDWrXJx_7wNlt1H0O0IAPxS2XSmZ7jXjMOYPmCyUNxEiniNrguFoRkyY4F7mXVKE1RW30du-fIyNJCFQAHcshI7llY8u5aWaq0UJ8ebisewMkqId1PRMDjsVG2NnqEwEFsbW3aIyyb9DcXbFokZqzuelheugY_SajhfX2h6E2UcawT1iqHa6VdVfl8-o2_-N03Zl8_NKU7dgsnjwmt6YF5SrJ2OdLrH0SH0gvI6YNRzK31k0qTDJl3Zx4sS5rbhKkxrUUFftasyQGOjp9jLVxXdXLx84jP2XiRL84dXQh-oGc-N_7OpmTdHWkVnY6-L7uErWT0JNgZlohG-xlXkZ85WdnKcM_TOJI41A2K4k-w5YG3Qdg=w1232-h924-no
_0cEfkkONZ3IWUIwwrlGP1sD5CtXRCDjQ75oox_1obIlU9dUDvR5GaUshiLEdvJNC4jUddeTfwvflD0NSKoLfwhKYp2uPQC8SMYGdvZxFy0TzyRAayxCqTc8TXV_1xAK7R5VTGhTjtzPUeVJzYRw_3bn1HQdn7tDSIw_AkbA9MCEkn9PdzAJdLCjasPK_2rTwYxwGTdUCcxSy21gAQAdahqnosYt-wzqm4e9UXKniokZwMY78RpbCcUgZLXHozGp5CTPlI-5a2uLQQW1oDWJ53Z_JoZDdTcrNSkDy746NWWMWbIEbRdOenLf3FfTuwJHKI0kCZFIk0h7lFbINvfqiVMs4P2pgeZr3GGv397KftB-0muz5W9vEZaqnK1igIa_oX29PzpbqxREKPhfzOXfdKuwMOIVf8QEwiiykQ0AtheQJqElDMZJmXpD_pyPtCfOpscW8lF9xmBO4Gv4Odtwl1SFcvYAhoXdrH2QQKPqpZeKhTkt0vg1uyLXuHDGfVJgmtXGsadPEX--qr3iUohECyI49CvP1z6-2_ttA_pwRr4QblND5kGE3URQ6tC5TuLduxcNNwsb3v5RcQ_E2QTc3E4Rn7qeTtHGT4z4MepKbQ=w693-h924-no
Sadik
Great artistic work. Looks like Speaker building is more of art than science.
Its a combination of both. A proper designed enclosure is not enough in present scenario, it should also have good aesthetics.
Sadik
Thank you for the complement. And Sorry I do not have an Audio Measurement Instrument to measure the response. By my listening Experience i can say that they easily hit upto 40 Hz. I have used ribbon tweeter in this built which has frequency range of 1.5 kHz to 33 kHz. Earlier the tweeters were crossed at 6kHz now i have crossed them at 4 kHz. This change have improved the region between mid frequency and high frequency.
I am playing them with my class A amplifier and the sound is really very sweet, The lows, mids and highs are very well balanced.
Sadik
Looks very nice, see if you can cut those spikes nuts popping above the base plate. May be without that it might look more plush and neat. Just my opinion.
Thanks for Pointing on that ... Instead of cutting it i will get new set of Grub Screws of short length... Thankx Bro...:)
Great efforts in building one, more so for updating the whole process. They look fabulous. At some point I had the itch to do something myself, many of us(excluding few like u of-course) only think todo while few like you stand out to make one.:clapping:
I don't like the stand portion though(just being honest)
Thank you for your complement also appreciate your honest reviews on Stand.
Initially the Stand was not the part of this project, So I didn't think much about it during designing of this built. The Volume of Enclosure is as per design but i didn't had idea about this listening levels... Also there were some constraint related to height.
When i tested the enclosures i found the tweeters were not at the listening level which was causing a bad sound image, it was like the sound was coming from the knee level, Hence i had made this stand to adjust the level of tweeters. Now it feels as if the singer is just sitting in front of you and singing.
Sadik
