CAT Cable is carrying 0 volts to 3 volts when it actually transmits data - I think & the material used [purity of copper - alloy] / geometry of that cable [twist] / the shielding [number of layers - thickness] / the 'skin effect' / the plastic - polymer - teflon used / lots of other materials in the chain can / could have a bearing on the data that is transmitted
Not only does it have a bearing, it is vital! Not only is it vital, but it is designed and developed, precisely, even down to the exact pitch of the twists. That is what makes it all work.
You might notice that I have talked about
digital audio protocols separately and differently, saying that there is room for doubt in such things as USB and Firewire. Still, I think that anything over and above  a properly-specced cable is not necessary, but I don't say that to talk about
these cables as audio cables is entirely wrong.
With networking, on the other hand, data is being put into boxes and shipped out by courier. We do not mind who the courier is or how they physically transport our boxes. We only mind that 1. they all arrive in time and 2. they can be delivered comlpete, correct and in the right order. Until they reach the addressee, the contents of our boxes is absolutely irrelevant. Whilst it is in transit, it is
just boxes. I mentioned in passing, somewhere,
IP over carrier pigeon. It's famous, Google will find it immediately. It is amusing and explains a lot.
There mus be millions of miles of Cat
n networking cable and flyleads in the world. It has not come up on by chance, or was not discovered, as I said before, growing on a tree. Commerce, to a huge extent, depends on it. People rely on it working, without even thinking about it. It has been developed for purpose, made for purpose ...and works. People always want or need more, and for that reason, there will probably always be Cat
n+1, but that just allows bigger networks to process more data or bigger families to watch more HD movies: it does not (as someone has already posted) make the data any better or more accurate and reliability is already built in: it just shifts it further and faster.
Switching back into the courier analogy, our courier is, in fact, so good at delivering our boxes that, if one goes astray, or the contents get broken, he will make sure he returns to pick up an identical replacement  and
still deliver it.
It is so good, that we could not wish for a better courier. In fact, a better courier
simply would not be possible. That is why a "better" network flylead is
not possible, and why it doesn't matter if it carrying music, ATM withdrawal data, or connects a remote surgeon to the robot knife doing the job. And why anyone who tries to sell you one is wrong. And why it is a mistake, based on various misunderstandings, to buy one.
(I do concepts, not the technical detail. I can make jewellery, but I cannot explain the metallurgy of why some metals get hard and brittle when thumped. I leave that to the engineers here. But frankly, it
is the concepts that matter here, and how many bits are in a packet and what the header fields contain, or just what happens to those pulses as they flash along the cable is not useful to us. And my TCP/IP manual is so old it pre-dates things like private address space and Cat5 cable...)
<non-DOGA mode
			Yes, there is no music being played from 1 machine to the other.
This is all data in the digital domain.
In fact 0's & 1's leave the Silver machine - through the RME - Hammerfall AES - 32 via AES/EBU Protocal & it only converts into 'analogue' in the DAD - AX/24 DAC. Until that point all the 'so called music' is pure data in digital form.
I think we can start to regard it as music  or, at least, use the word "playing," once, it reaches the sound card is then transmitted by a digital-
audio protocol. I'm telling myself that the clue is in the word "sound card!"
