saumitra
You basically need two incoming wires to the TS+/ TS+ HD STB, 2nd one is for your recording. Now the technician will either run a 2nd wire from your existing dish or use a splitter to take out two cable from the existing input cable and feed those to the STB. In my case, since we have a common dish for the apartment block, the technician had used a splitter. I was concerned about the signal quality with the splitter, but he had shown me (from the menu) the signal quality was very good and I was convinced.Dhiraj, whats a splitter here?
One other thing as someone has already mentioned in the settings-->user settings, you have the option to reduce the time for the channel info display that comes up every time you switch to a new channel. I think the default was 5 sec (or more) and I reduced it 2 sec (as it was irritant to have that channel info display lingering for so long and blocking part of the screen).
