DIY Audio Rack Made From Teak Wood & Plywood
sadik
Vadodara
Hello Friends,
Back after a long break with another project. My next project is a "Simple Audio Rack" having 5 Nos shelf. This rack will be made from Teak Wood Blocks (pillars) and Plywood. Below are some 3D images of my design made with CAD program.
IqezvBflEmkr1EnyzoN9cZaFSAxrMKmkVWWNBeV-T8-_Of8BNYz-9s8iTmxhLUORkzhPPCGjP9g8OB1lv9ZWU-mjer7IQspwkei0PvxC68CO7SwQHTeDjR8GqoR4eiSKjeDpNUdVpaVIuBPJZL0N6WVOhadDykCcespsuG3OqdjOmt-Zz2fdAts_bqltRNPGBzR1gWIeVM05B2DZgnfQB_uzILvw7f9_-BqTPYB1FnKJbflChi17LWYd1EJ_ATMW21Cn61ieAm3v1RMpTUH9X1LFJrFT3qjA8qtAezTUshx1KJio2Fdtn7ecfUGMszF7mqVja-00ekNU4sQ8Yg20VVhkFPhZM5V3Krt56ZVvhFuvaKI121ynkb4tdvoPMn1CnsShR8Y8YY27EXmmjkOBVGr36uNsxHP92KFWMOU10DPJszdJT_XQ3n_nkDiFhZJMQqVsO6YWtuSTOPCovZXiBaBqkUr5RcGeTUb_5TNpWFy6j28uzHYb7v_nCIf8ZiCtFymFrX_FAgrkLGip4emCRHezUdJS-VNMnR_JOE_Krt7IQZN4nCN-hec6i0aXqujHsd3rAE2Gaega29Sk3n5PUfeYvzQUxRrQ1UKR5KY=w567-h683-no
CseNRKlPF6jz1nx45gcUGa-e9-vJSK34wQ2klO3SnPQYexWYajCO1dWE4iizyZz_WOTuNGGLEjVd5vlqQYlZjh5YwpQ7Sju2SjpVbIXYruCaRA6pEl556LP-y-BoOPv8-r-8B41mNcJLl4jTLM6j4fngDdlo0PSXLNCLq1DST2Vcz7VBjf-v7oR_ezrPY61euq_SBCahprvxdtmK-b_M8vnZHrBIaex8F0XxgUszKrtzjtq0V8eKtKWNb2vtruFRNP5otOxt5OEPEXobB9Z2XKYKjocd_Jo2CvPli_Z3X2JYKKCvDlvqfMmkg5rOR7CbFEl_IFv7xgwepoJO4MtJizlBAVLuwNSTFSPNsTxQ5A2Z0Q5weiggqJ3tnR0Cj4J-HULbzKqf67zgPB9ezzJD2bLkBrdMw2F_5821OF24oXcT3VQXLZVXs8MVOGQQUxzwyn0RdY0GI9f6Zta_F_8fyDs5lFe6geLCOZZf0wk3H9UJBuGhZe_fOQGLQzLO0xNu2IkISZi4FeCNc6W5YtuIyV3GPGnSPRyRU2VO-6MuQbps_cmmmGHK_b8tFe1aMbdg6yZBK6Fj1EuO_KBPE_irGw6HAx1HK5evxLNECZc=w537-h663-no
IixezdP7nTtVqMMLNI9Tg9Ei8XSpH2xVWQoJhmnwliIPpF-KEIcbQHA07MtqxlosEFcqnq7PXHh-12ubAxE0IDroaeu6ApBOZ_vO38ep4KR75kZe5pqPt0WBcBYYYbzbLsfyirMXMFBVhdtlm64Qi3ZX5uVppZmQ4S4H2vDOe1h-TPzNM8VKvWeaH90IraClgyPWrPuBA796ZyVo4SZzdv7y-ukjdHN3EydSZFak18_nyfkh_iaHIkHSXl5u2s5kVMIphgaPPVP9xt8UboDeGfoukNaaJedxlST458OOIBWCC6tvutovPK3z3EIiClAP4nYi8BhS2KEEplzlHjjCkJnRCz1S9jPoOwqruCqVjTtyZnF1i54f-rcRqelQIZwi5RCpOmJ9iXW-F-c_tZFgOuacbNQ0101iW33BdAUFQQw6-GMN0OJpXyC-lDie809hsqxZNPOMlR3OUgsOOZWH38WQol5PolkmBrjUCdbVgXY4Ydo4BghiHIkPWb4jPEQItjMeCNeFPhevMmcwC6Rhn5umjXce-D0OfnnD_JFmunHfnHaIt8cxv2yrJ4KRhxuVBODRsSa53l_EQzTj7bIyqOtCnTCuBKQW11wbeAk=w797-h869-no
HMwd60C4sKM-xk8DZ1IttWWbNLEUBixCN1k39qJR4lzZzfGW3j3ksdVg4xku1St_eSUV6zTlDu00YUaA9s59RWAMbH3QCzvunsuSIdlChgz-3Ib-2wK42avqRsi8hAKg_TOp6DLhnyRRlWCfF4nfUcS2gp_Npg8Pg6uFpj9Xe1ZQ4Kvt2VvewJIzB_g8HWa3sFNSWwATa2toHY1KgPCqU91OgAjFSRHbjnK0a-n8MxBDuyWRUE-XFVflVDm-szwQ_vTq7-9cgIbFTRoEvdQUVYdcsSvVRYBN1jSjZ7GtfN2fmIe5lMqzFs_RTm-SC5sNG7GgoJR1kB_MQFjSTSnhdfe4u0ZmxIBxS7z4OJxj5hR7qQhvIAKE9AW5KTqHPuESd5_3l1EzJeGpo1IBMDyY5d5Z9H672EsNDP4niHDxjrjC3xJRWe64g-KRBkuliu0CVrrHlqfbTfD7nAKVhz5kdNW7is68eCaGno3BEZESCZuIdGmzWwwps9P4VefjZ52jNJ8ZP3OT4o793Y-hxDW4NgZ0ia3gDHtBVrplWYTR088K2l-7DR4mQG1vVdsHKcFBbZgh0fJ2uVDgmG6KYpY-7Ag4FBxd4JeBUl34WiM=w665-h793-no
The 4 pillars are teak wood blocks which will be of 1 mtr (1000 mm) height. I will stain these pillars to make them look dark and cover them completely with clear coat of Malamine with spray gun.
The plywood used for shelf will be covered by laminate on top & sides, bottom side will be painted with black color. My budget will be around Rs. 5,500/- (excluding labor)
Cost Break Up :
Teak Wood : Rs 1,100/-
Laminate : Rs. 1,300/-
Plywood 18 mm : Rs. 1,400/- ( For 6ft x 4 ft Sheet)
And Another Rs 1,500 to 1,700 for Cutting, Color, Glue, Screws, Sand Papers etc.
Sadik
Do you think adding small rectangular notches at the rear end center of the plates (something like below picture) will help in managing the connectors/cables in case the rack is kept touching the wall or some hard surface. Just a thought which came across.
Very Nice Idea. I will use this in my built. Instead of sharp corners i will make them curvy.
If you can try putting sharp feet at the bottom of the rack. You can check out the look of the racks at soundfoundations. You can also buy the rivets from him (magma) the owner of soundfoundations as it will help with vibrations and also from a look perspective.
Hi Sadik. I think you should put caster roller wheels which will be easy if you need to shift the rack. Also consider a variable height adjustment type rack instead of fixed type.
I can make feets myself. They can be fitted after completion of Rack. May be later I will make the feets Just like Spikes.
I don't think using caster wheels is good idea. The rack will not be stable and keep on moving here and there. I have two options in mind, either to use rubber feet or spikes.
There are 5 shelf's at equispaced distance. The gap between each shelf is 183 mm which i think is more than enough for any Audio Gear to fit inside. (Apart from some "Class A" amplifiers)
Keep it neat and simple
I would keep about 9 inches height to have higher crossflow of air and try to reduce total number of shelves.
The lowest component will be heaviest. So keep the height maximum and progressively reduce height allowing for at least 3 inch ventilation on all sides including from top of audio gear to roof of each section
I will make bottom shelf of 10 Inch height & will use it to place my Class A Amp on it, I will adjust the difference in other shelfs, where I will place my other Audio Gears having less height & weight.
Castors are convenient but not really suited for audio racks. Most audio racks one can buy come with spike footers or bearing ball based footers.
Hi Friends,
Today I reworked on design and as per suggestions received from our Forum Members I have made some changes on this rack. Below are the new photos of 3D work done in my CAD program.
Modified the shelf to manage the cables on back side. (As suggested by our member Mr. Vipul Patel)
rutmiUlStIsXJCCvhQXeY_1adO_u4BxC5aZJJ77l4micm7rCsgdcFA5IQIwYtdDtQV3T1ccSM1PqE6nCfV5r9pC_O3a9eO0YAllSqZSfcoriAZmjQeURCwqTnPgknnBGBZwTIcJB0fH1QEh_dSUh74FnznR47CRIlUzpkAc7PAtR67qxnOicI1L_DVjhSv5YdVLEUul3pn960-XZJ1uyKakYd4II5XaghUNhzbcVUv_VbkhWKogd8o9gzQ2RDwJbzoiVUfWGgWZMxV5XS-8ZkkNfUpgpA08ZH8GzPpYOpOER5PuiMUFxg04jkz_QyRHkm26QGjxPKlEwH0iHL9mNUTTvZcnG2EpRRjiYOa_JLpmqWu1iJZ7eBvsbMUrXevUVuQg8FQ4hiuVG8pRl33t4VgZUTUIbT5hfYS86jcWUgTXuioD5jozcd4XJo-D_3wfQOxqthzHqb6F9CMPrBkmrqugfWw87AdJitEp5J97_Z_5RRyVGQf2dr3crLfFWHo6seAr_KxAzl1PKiCGIi7bpoyh5tXNsSFL0gAUTpanxUvSVpsuUgR-nTMZKzK1rCvx9XV8aUhnuESGNW7FCG8jk6qVZx11X2qPLwClCFvw=w981-h837-no
Modified spaces between each shelf. (As suggested my our member Mr. Sanjiv Nayak & Mr. MPW)
INPuBiRjP6T8lssaRjXvNSz9-YPBnHHxPryWiOJ4niLngd-d98amynWpaLYd_TDwAQBww8NSS43LUpJe22AHJmqhCKOlo13Ojqcc_84JGKeLmHD401sTC8wAhBL0t_VICma850-BGTK65ShxoO79zpO7SlZtfReGLus8a_1ktSmlOvnE4p12WgGroqHLA16KEBFGIpcirDX8_PtEX77vkA05gMTOVPSDfoYaDrYW7haP3MjVAjAnaHvgqIMDe54Var7uCzSclQ2FhjibVGbdJ1E9e_tkBlOO7F9bQnn3apRagS87EnvdILDneiy9ngJxCcvaLwC9Pae8quJ3p_cnncH_rhpQJFDNH3gr-9qwfYpMnP1qtI31QUR87zc2jdmF_7nkz1DU_HVZPzjdKbCBq8sH5AT8Rd6BJSOCDlikvMyTiJLuuy8f5cy70q0f6w6QIlEoEXJ1ilFh8liTErQZBwEfzdnFEPxQxEk-lI5Pt_LR_1beOaMM33XX_A15SIkkVCpMIWmXmIQfHAuJoP_wdCtaoFKGCW_0ib4NNObu7SDY1N5q6RJzgJ5rLy2sQ39HE2ZI7m2eBjxwCGBgop8DTLCm-35gsFMkw_UXzwI=w553-h785-no
Front View
I-RH_crUNiTly3b0hb6HUrFEGe6fnSX_ttKJ2eTY2HcVZpj5FDiBy5VT4vAMtrN5b5BAN-FXm10cBVvV5ITs-lsW_kKp-tILEpUvtlhOBOzyOoaqD-8be_-YDbt0KR-m3ckzVbttBoFqishLYpC0Zdt-O2t8nN2HENxrehYeHjk-w4Odi8fxm-mho_jfZeIkR0b1ItcpfklqkTx3LNPXd3ywi8wftNMhV3RiF237tfAEhFn2-U8KNzLiTJiFj_oyvGjUc50glG_xgf5b0dSXJFpuGSOuzcYoa4-lgjDxWPvNItqMAC_m8gCiP2Vl4pE87kK092pK4JRiYQ4Pv8F9s1eF2o_tYrTxRgeVMjLRPVeZ92pc61Ia0FnrcOaTrOuaKSbTpzx75j8WoiKo83Kuqo3ozisxg4wCFIDzD10lJnurBne6a3k3BaANZ1Uh5W3boG1yMf8Vb3IrIB-HvJLuJapH3Nk6P1x0P4Fy4t8GfBvoOURwLnTXMuLbzACU5nRHRoQsYttN_ArEKA0LlxmunMFV7PBR-jJej6nXL8fpp7I-mwb3T9QYCSDkTgHi0IqZQanavB7pJh62mu0YJqRok8snPzfiUXB5-xZnH3s=w585-h831-no
Side View
BuLLtlJUDaGfDQPG8zSVTeG3jSt011O5cO7O-LT0bP8wJ_N4qiLy7_cB3JIH9Lf13LIJ5xWTnE-xcZxbgpp12dYthxg5FOm3oAmKzWRAPNGQp_YSrFJa79DbF6zHr0dhfwHXObh9wHtl8RFS-35xjvFfKxWV40M4mCjwhv51LWM1uPQCAiUAV6Lm7Xjpmwn8A5IUQay_RbGiAO6HM_eYT_fQhsjyHA8JY_xSAxHwsE08vy0epDiRAfEu3XQvoffykKZIRjlOaAtASfkCr68lwKS7RO7nMDhv4p6klhVV0tQvS9cQW6HHiG7sOJ_FrXfHmH97fqmeWfhE27tLVGTwJBDUNI8hjxTsAYt-tMyJIBxMF4q8pQIhNpMloEJlXfQPrjIJPrXk---GX_cXflfMogFbD8-B8hcD95rBhQRmDzx0HxbXPcAAa8XbIfjQeV47wfE-h2nxg5VHfUv8BmFTScSrjqAyzagI7_ADmW0s5gpRkl0y0JFSsM5fMBMqeSITFZxLxJPtKvH-HcBb5jTTE84pIoFJc2YRQwfvUCuO8ZBOUn2_vMYQCkEBTe7eGNm_nBOofjKjV8cOhHEhYTbmR1vlvYkkFMCHFQIZZMY=w445-h841-no
Top View
NR80gdE9nwDKKtw2fqp_HS7emON_Oat6ojv93wVfocZbqw0dq_OT_SDE5tlWWmHCu--iXyp9yFcMZrglDKhIovbUdCRjqWMy1hj4nt93XMb1P5KvubqqvKxtZhioN7LhkfsQg4ftr39qjrgeBSBdYAPJKYvWkDwbLsDA1u5FcbHGIKrpnRYWjX4cVKYemI2cDi-zbQ_bapir0Y4xXlic5m8-JQ8ucd-PEdB7RoBXkO3af8dz2dkr1dNROU7FJcrxdE-p-qwJ6GMYQrX2DogmPTcSyLby3yPxp39b3I312ryt-ZcMBXRCByybQ6NLqC3Ihz8hAnBSJDnOCw3GZLS4Qft_0ai7HoRkOHEusp8CEjr1gI9KLkSZhbXjWG4mh4x8ADT1G3FqMGDmXy6C5BvAP_LneG_rcZ8kTBCg-XerkbCY2IDf8gginGKZdQpFFWKvQrTPpIusVAWjZli-fnMIHchTTWVpAPSgi5g_GSguBvq4yy2aL_TjKR3IeBNCb7UJ3AJB5EZU6gtBNxy4LFsyuIVJR0bxDqkIEli9T56G1mNrNyhShvJOA5pYMFQk6evJMDxZu7YapWa8iV-t2obaSBApLIBA00LGhL_U1aE=w1093-h833-no
Pillar
KPk3hIhE9bcPR9yXrvqkmvPe_OKN4Z3WClezkkYXveDUEfM7WjWLYeTEileObhR5Oz_09HQPtHypkE29cTTn_BOp553p599q6-705hDBbV8JsVijO-cNJPXcFN7EsvIpZMcJcFVtqqdNJxG4otbhg35WYwjQiXoPfDe-bYR-ulqZACiY5ay6JASFu_UdGkzj2Pa5nCWvgkYHHDPR_5s7Uaey6wq8L8vCYp10MxQbe57Dts3b4eoBBdk1rLJ22zZfGY55bFT41-yARjopoDmPoAnP6xDB2rnZLu2YHtpwQg5y44vWbgmMbo2bKUqQzegKgWicnH2rPrGa709MHXi2zAKCs4KmFoc9bvBAbLsY7UXMGOYr5sQWN5TZvGMRpCS-5u0Kli2t1-Ws87sC0wiXQ9WmwVmsPuMquRzK_P9TKljd5JV4kxrkM2Rgzg_Y7TpzMs3QI0-UZn8lzv2jJ2GXQbX14ChtPCQTQ8i4R6BDJ9hBoRC6knS2tr-5eagYUEAhGlAt-WBFJExafVx1RUGKURw4JMYK3_EJ4ssJW9SpK5oI3BNYJYcCN9qNeCv6EmUd9Gha2m5ME_eothJ0Q8fpwtaULg_5qkLc-zaZJxo=w123-h839-no
Complete 3D View
lubM3fqdrzYm7NTCr50zd6IAQEOuNLW6dIoTDsLUa7HANUR4WJabH0TLIngAqJA3GnR9EdiZX7Itxbylq0W2p7SMpmSszC9wEiPfEhbPsiiVuaFOC0x2UBDRG6raxQDHhVMmbVFAs1bOacw1IXJUL-u-SxqCT5un1deVdCQrSfgWWyZEALrVMB3f58ID1xVZ3mKadXzT6GxGx8F_2iOhoaqEriobDws3_988l8stB9w4RRVTPP1glJmuGnbOkLG3tmmjU6njIAw2l_bs4qddaQ2ZY6BhNZ-xNb_LD_gWo0t0i88qWpOo09axPuiFHQSUeCSP5erQ61IFVD3py1FkNt2OaQAfbI3wQw3hWfNqiBox4yetmbb14AhqTh22mvgr5fCpzbOGAwEbH-AXLOoTj3pmZEju7MfMup48KEYJFdLDEktO4CNWmdDrbMsshqCSdq09uS3SPIr-PkLA0lsE0V2Eg_tZZdBl4wdbZmhY9ToD-Xqs8NajdM8SP19yl7Fq-YaxOXuDIdYiKf2y5PssIWVnpSOqXZr0QcYLwztgrsMJm8FqOycc8-sICk2b0pgc91zfCeyyCPvyciFuSzMxOAcGx8Z09frsRXZv7xk=w557-h837-no
Thank you very much Mr. Vipul, Mr. MPW & Mr. Sanjiv for your suggestions.
Sadik Bhatkar
For cable management, drill 1inch dia hole towards the back corners (both sides) leaving 1inch from the edges and run a PVC pipe from top to bottom. Two holes on each corner one for the power and one for interconnects. ;)
I don't think it will be a good idea to run PVC pipe from top to bottom, it will spoil the look. Secondly with just 1 inch dia hole it will be difficult to pass the power cables through it.
Sadik
Another piece of art on the way. great going Sadik bhai.
If some ambient lighting could be added using LED strips, it may look cool. just an opinion.
Aniket
Today's Update.
Got the shelf. The cutting is done on CNC machine. They are 19 mm thick.
3AdTVEjFXRKnJeJNqpL1OKVbNB4ZpayR3zvIz2_OXECnPSLM7HX17LuNq8tsQadQ-cJaZXoStR-7QZj4MTVzP-3gZXthjRbB2L_AakDR3L4fKNoWR3vEMuOan0Vc6q0KVb8q8qjeh7_yqTfJy53hC3OGLTnxP60P_Kj1L79s6IExXI6rhBnx87uh6_bjt-cDUhxRSARlE4D21q386-ILq1mFk47CI52gR9rEvqAmj2l32e41F4LerUkpBfj7v2Qz122iebrdEWk8GZ_JRiQI-_kfT9Is-3qee5PuMn-BbcWopkvQtN9xUflc_Muf_IOk2FY3wLndK8axCHyABO5Mo3_mcisKTIHF-gOOq9BvsAyUNkzZHAT4NInbyRRbZH0UxKHIh-6RD8hp0B0iOlWt3lTQyrEWWEjVIXVkOe8AWHxJZPfn8WxqrMOU8yG_ENu17xQkNE3pIt2QePCLMKz3Wnzm0GECH9OwyrtDO1O9YRoUwoSLHRvR25hGMn1De4FQKaN0mL9UmtDJBomI01LZDNdk-0IMvygGBEo-wgkOL0JMO55z-LsPRE3oW2UZG-Ij7cuBwDJsNIUrswXosbIBuFOuyLi7LbeZg3rkOhQ=w1236-h927-no
Laminate :
KbYWBg-9MhrK_pPiFX4m_2ThH4HF4VY22EId9x0pHc3gdNX6IWIZSzWrLhgzebxwAS5EVkpnpY8XTynLmXDlEtDB8VE-Y1PFSr7q_SKgN4PxpVF1_heDTngWvn9RJ2ePAAXhwZ02OXImDixpDJfT9_MM1uAw7S1WR0W-0cnUJkHhS__7Ps1MBuGZoFzKnM-SVL4nrJMNYfjkPiml9P1h_I0GdHXDmFDmbMNx_pSbL3FwpRWPCEr7mHC2BpKEdEWuGoGNIKQH6YkGLXCjWW5I72BmBFo_bBtrlhNDOyMd6JFAH0cw7u9s_-Woj5w-lT3j61AbUTqjH4Lp2hQSLXUSEZ93vYII86XhtaUQQwwDEz2pc6RPSHeLoWEejI3I_AMDPY8D3sNuwp_JsPNfFsPbSJSMob55Cj6SQz25lDTnNgWDNwnOjW975BY89KIu0rCYC4TqSvAh8dYsCLUKDFST1VjZJk7bUDrRADvxfY357VbN-VFQvK0H3h6gU7t2kj9WTeAMAjBnqV3ZUlvu607Q0cHf1-AvPkP-Q3dKs1DaY0QRtH8ZqYbUTi1tZkltivBO80Ca7vTzOzdiYVaWJFI9EP8jibrDJQuYdAmZIno=w696-h927-no
Texture of Laminate:
LYGP-dkuIhOzGOGaJElFwTA3hAqaTbknRJjMulQPOkTXWZD3YeqSsFiCxxV2M4WUs0vI5tSwl2ihbH1gagwLYWBjMrBSVKp8a4_PsYrppQFn_Z6tWCn9goIA7fYyXOoKTPothwuGKOO3k-V8rCeOP3OrSR4kY1A1SM-aP6rOHIRrdw31fnrg_AyrUeh1oF6T3MrMMFw_TQ1gIrJizYoZU4DjmoibiH8LoNtKtS78cWc35jn94bY-8MhgdVXVmfYTeAbYSIjAqIStzXSxCS2t84MkIO8Fn86qdYsAy7HZJZTuacLbJpLjkt0YfwLggCjQcrl9RWRbnsbFozMKFHHVw7MVGv5Ry9OeyfO1h1LvNgTSVokiak0zP61sd68p5xTt4e7h1MqoGlgntILvGd4Is4iSb3riE0peKjtBveM8KiFIRrTDIjfxI-6taWifUvKtzcPLAu1x4HAQ3G2h0zcjfpE6cULfqXX_Rk5HgGaKVOZsT9uzLzUstur0fl0HkvA4WhxxNmwJuqnrv_36A0qIZ7MS7pqmWiwX8j2o6OxDVtIcKdYynjbvShl9ZxsN64p__XqDJ9AVX1GPtcvjl2K7LUBloOIno4BNzyDbtrQ=w1236-h927-no
This will be my first experience of working with laminate. Cutting & gluing work will start tomorrow.
Sadik
I'll reiterate, lose the screws and dowel it! It's really easy, if you get stuck p.m. Me I'll guide you on a video call!
Thanks Sefan for your kind words for helping me out on video call. But I will still stick with Screws. It will be easy for me to dismantle it is there is a need to do so.
This is my first experience working with laminate & it is really going well. Yesterday I have cutted the laminate sheets as per sizes and glued them with Plywood. I didn't had any idea that it will turn out to be so easy (oly with proper tools and little bit of skills).
Below are some photos of work completed till now.
Cut Sheets of Laminate as per sizes
qq4z1FvRWSmnnMYjLg16s47ExCNz-YajidPt05-51msbP6sULZQjj0DkKLtGEGDjsQ9W9ESvyNxVGI4u0_5KYlychW_rCaK9RLJQDQ_9cDk8KYT7pDxVk1GNhqKmg5AqWdz1FH4SJLUhCWDZAsJZV_8H2seClgXbqQIMJVdFD7nQ-poVpVD0K4UP7kvP6C5xoHLEiHYB1NZjeZ4nQRgsCObGmP8eN5oZCcTL9glVfs9HQ4RvHLb295Ty86htUHrwx4wSPrgCv49dmvM3A3TByEUHcjqV06ynyRAm3MvqcmJbLJKHVTZjbP2pLrpcnHGAbMx3SOGtUVbCBfx-aFHETZbNosIVwLzX5cbNxZ-hX5BptLwX1JfaZ7WTWmaOMCSJU8LhDH9i-FrKj8B8yAm2u-t0aYWFVt2AvPggahaVzZBwWQ1gV1Yg28d9dT71NR3vnpShEO__uNEsaSVWjCXV1hy-JEY7DdNYB1e7JwL5ZdjOyUD1LiBEuL9FB8NfPrYPZbL5aaJAdgHz4h5HU9hYWWBz7djij3JKAXz3VafR-qgNH1H4_kSn4Gif2EHZyZ6XgO00Mw8LrjHJBMsz6d_DwEQbNX7pdNr6sKz2rq0=w696-h927-no
Glued on Plywood
JvfoyDqu13NSU9VqHqxCrViSp7Wh2TdV4RUOosblX22ey1-4LKCluQNBeheajp_D70p1ZRbgKoBi29wyhCL_5QavlneTcyiYMz7dB76jYsLNkwZjIL29w6bHdh9nva4xvrAOKir1l1g5liABxq58kRjMzVT2QaPBcRpnS8oZxNGCjSjJfvQFCPD7lBzni7CDO8vfyjssmECrvmoVwtGJ8zMJ7o8ix-VVQBZBS3KbgdhRAPGaJt1_YV0i8i54FM5csVtXDB3ybWYtTV2Xw0fUn-PAMVP1q0SbTENaZdcJO4TXHJa4VNSjn-p4XeIxwokt9ck0NIfhIa0_PuXGBrsTG-e3qKXJkVU8U66TyRgnyGM1RVmMcwuK-h9wohyGtw3P6d2BNY1v9M2GBA09901EhObxfBkFZX9RC9W74I50PBTgJqn_sLxd1Om1qcN7AKub2bOUQ-rZmi7fs4KkT5PerH6W6SS3HjrtIfSJdgEuSR2fTqxWJirZzRJ0sGZJzQi27bfUSbLSrkK1ZrCtUVjxCSL3mJm5BTvWBlKwybHR1brWkfO4qM-saLx8n4sNKHuOvop0TuzDuW4nLob4U-dv91O73MBvrs-4oxuqVnM=w1236-h927-no
I let it dry overnight and flushed the borders with router in morning.
L_Y0yaMt6c7Z_dLMN1qLy6DhL0QcK0Q8EUfbUF02tGyd9MeP_WcA1Izq037RwJW6H7qqwGcS3lcGLlffQUkDj0_0Le_zRvtNJSuQLSUATPXcANat_Jc8o9pwT4gqT1tYl44I7a3M9pbNooVoppq_w9cm-eP7djuDMLM9Tp6WJz-EiBlLARt_aSew62B7AyQsNMZB43X1C3tj4hpA60-_Pu8M8E99Isq9vEhms60b2Xkseb2Xdwz4-VtknGazwfj-Oen7UnZnbpRRgCp_o2lUDl-yp59x8Oc0XgtaFQPS_-rLjXj7NYXD3B-MvNFI6i1pHqYMEjBegG2Rli5BdYCyijstiQLVkvvla6cS1PK1dG7c3iwksokGn1uor0L-J8U4fnWNZr79f7v2fRTBf6SF5WH2_L0ToRHIEB3lN6F9JCtLp16laf6AqiP6S5a-Jq7PBuQnRiaFlSZmyI1IYhx1X2KtnBu_PgWbzXC69Z8wqd0dZRKfZxTE-QXl-bx6NS-rohLTDH25jcDq9tMCrTvD-VhOxofSmkUAfje_geLluK1uy1ab8aPpt3BKEGH58e3tQ6oiXASpXJJXrbTGK4vNNlBVh0zzsJbj6y9gtNE=w1236-h927-no
-RwCYOU7HWDojhnRnRKrtisSer9rAROTV341rsyN18JH3NYV2UGzOF2qPV9LezmWwdDQZaUfyorrbhjgQCrxx947H6Epmri97YZ7uKqxW0PKJi1-vzYFXOB_VBZzFKP9NkMudKce2L6ng-7pebjOLpSP6hcvaXcaNiLCj_3TvzzXp3xlmIZ0niRgHFtGEgO5xjQw2ZiOpx6MiSoOoRcR9mNwJiXUauE1s7DbKnPu1m2bYsKf3MqqE6ElQ5gcL_mIQBip4AKgkkOECfCKmvjqFzlUFBBsaHHx3JUlCljMrvt-bBmM9SdLAVWIeaTDhil0RE9EwPBicwcRYACe5sC3D_x-6gUweDxTyLVs4Mrv5fSZ2FKJrd8ED1G9UBCBQq7Qox3CdLNDA5su0xC931XbqksPrXmT3K8Gd6aVa_vxXpW6P2gj7FggPQjgD9MwqKpkMknEssu1hv-H6VXDJZkPkLt-tUFS79Afo-GM2KYtKj_Rrrv2s8CigvVcdSjyDDuPsqZW14OIK7iyZBXgXQmE2hpwLhYNG-ee50b3HGMdzRSx54PL64rwyLirwpjaPHvM-aOucgF5485uOpUE1tlvDRaI1IfeO1k6wriPWgY=w1236-h927-no
OT1TPRIp2j8uOP78FMAudjkyiKvLxFcnDQQwtnueeXYi7921Y4XCAcpTr8i4mHungELYu30zAVqGxJC8B0aDPmdcZV5lH6SUoyD9YsWt6ILNSrgiW-K_icze-9PxT5hXfiHt6zfMlKu82PWNTiQqVjkdT8nJ5pYGpCoMsQ8TwgYWGKTj_wqev2qPaWGfcPWsSa7Na5G4icvbix_IhezE6ML0ed0C5DE4IGxdeuYpVuuxVQNVePv-ebngi0AguEmVQl1ZvTyK2wE4QwQIx95BbWUqdFnlGIXSs7xQW36dqg-lJ-Ci-pnaxVLgYQ36P9RzF46RCabHNpSKDE1i7deSQVz0cv8zq1QVsbr7DHCBpKA9jT60Txd00blKyM8lkl_1Hd70_tpx4tzMrA6faFHp0FIyVtq8wn5Pprexdpf2y21kEk66JD82Geue5PYNR4ryctwUfute883ic1LlMEVwK4-2bFqrQdLm1FO5cqsqo3bXEzqHvotiwU_r0jYcvH9dKG2XFv3IukziYollK8vKvHM1ivZCuXxRcx7ifyLFR23dEWkVnCl_Xwy_6UP0WWzkGeRmyVGQPBjaKH1-HfMMhKhk918OeuC4cHdW4aM=w1236-h927-no
I have completed two shelf today. It cannot be called as completed because the cutted edges are yet to be laminated. So back on work now.
Sadik
